[Archiv] Ako nainstalovat T-PoT v Total Commanderi
Uživatelský avatar nofly | stř dub 22, 2009 7:46 pm
Zdravim vim ze to tady asi moc nepatri ale fakt nevim jak dostat tento plugin do Total comander dělal sem to podle tohoto
http://www.youtube.com/watch?v=hF9zyK09PVs jenze problem mam kdyz po tom co mam poklikat na t-pot.wfx tak se mi zobrazi
poradte kde delam chybu :cry:
iPhone 3G 3.1.2 JBlackRa!n
ned bře 29, 2009 9:30 pm
Uživatelský avatar dodo_mt | stř dub 22, 2009 7:58 pm
Re: T-pot
Vyskusaj tento navod
dodo
Apple iPad 32GB Wifi White
Apple Keyboard (Wireless)
Apple Magic Mouse
sob čer 28, 2008 2:44 pm
Uživatelský avatar Beavers | stř dub 22, 2009 8:00 pm
Re: T-pot
Pokud umíš anglicky:
Installation
1) Normally all you have to do is to open the .zip file with Total Commander
and it will self-install.
* A pop-up will open asking you whether you want to install the plug-in or
not, answer "Yes".
* If another version was installed before, you have to choose whether you
want to overwrite the files or to install the plug-in into another
directory. In the case you install an update or re-install the plug-in,
simply choose to overwrite.
Note that you will be able to overwrite the plug-in even if you have
opened a connection on the iPod. The new version will correctly replace
the previous one and you should be able to go on browsing on the device.
* Otherwise an installation directory is suggested, you may modify it if
you want. Click on OK when you are ready to install the plug-in.
2) If for some reason the self-install doesn't trigger, proceed as follows to
install it manually:
* Copy T-PoT.wfx to the following directory:
<TotalCommander>\plugins\wfx
where "<TotalCommander>" is the Total Commander installation directory,
e.g. c:\Program Files\totalcmd. You may have to create the wfx
subdirectory if it doesn't exist yet.
* In Total Commander, choose "Configurations" / "Options..." from the
menu.
* In the "Configuration" window, select "Plugins", under the "Operation"
category on the left panel.
* Click on the "Configure" button of the "File system plugins (.WFX)"
plug-in category, on the right.
* Click the "Add" button and browse to the directory where you have
copied the T-PoT.wfx file earlier. Select this file and click
on the "Open" button.
3) In both methods a new plug-in will be shown in the "File system plugins"
window.
* The default name that will show in the "Network Neighborhood" system
folder of Total Commander is "T-PoT", but you can rename it by clicking on
"Rename" if you wish. You can also do that later from the configuration
menu.
* Click on "OK" when you are done, to close the "File
system plugins" window, and OK again to close the "Configuration" window.
úte črc 01, 2008 3:17 pm
Uživatelský avatar nofly | stř dub 22, 2009 8:23 pm
Re: T-pot
no anglicky moc neumím to je taky špatny českej návod jste nikde nevideli? :(
EDIT: super už to mám už to běží mockrát dík :D :mrgreen:
Uživatelský avatar dodo_mt | stř dub 22, 2009 8:34 pm
Re: T-pot
Ok zamykam. Ak by nieco odomknem napis mi PM.
dodo
Apple Magic Mouse
